Ir para o conteúdo principal
Um smartphone intermediário da HTC, lançado em novembro de 2014.
Where is storage space going?
I hace too little storage available, over 11GB in system! Can I reduce "system storage?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
If you are Android 6.0 or later, you can try putting a memory card into the phone and having it "Formatted as extended storage". It will combine the existing storage in the phone and the memory card as a single storage.
Esta resposta foi útil?
Pontuação 1
3 comentários:
I'm running Android 6.0.1 , on a HTC Desire 820 (single SIM), it comes with 16 GB internal memmory, and I already got a 32 GB and formatted as internal, yet it only used 132 MB of it, and still do not have space even for a screen shot !
por
That makes no sense. A screenshot should fit in 11gb storage.
Try booting into recovery and wiping the cache partition. This usually works on the Nexus and Samsungs. It hopefully will fix your HTC problem.
por
I couln'd boot into recovery, so I factory defaulted the HTC handset, while it was reprogamming, it offered to restore a backup I had from last June 2016, so I accepted, and it continued, of course I had to re-log into most apps, but at the end, I had a system storage of ~ 6 GB, with about 10 apps more (that I uninstalled after that backup), and with about 4.5 GB empty space, again I formatted the 32 SD Card as internal, and now everything works fine.
I think that what I did, parallels your suggestion of wipping cache, Thanks for everything.
por
Adicionar a sua resposta
Usamah Sayed será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 12
Ao todo: 1,982
