Ir para o conteúdo principal
The HTC Magic is a smartphone designed and manufactured by HTC.
Pergunta encerrada
My messages has stopped loading it wont allow me to txt
i installed the new system update to my phone and now the messages never loads,my phone has stopped recieving txt messages also.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
You may want to try a hard reset. A hard reset will wipe all of the data and settings off of the device.
1. Hold the left and right soft keys while pressing the Reset button. (The reset button is located on the back of the device.)
2. Press Send.
here are sites that have some more information. http://forum.xda-developers.com/showthre... and http://forum.xda-developers.com/showthre... good luck
Esta resposta foi útil?
Pontuação 0
this happens due to the difference how the new roms converts your sms center number to the format that your Os understands mostly it is solved by entering your carriers sms center number using the appreciated menu if this not solves your problem try to re install the old rom back and after verifying your sms center works install the new one without wiping the data this should fix it I know it is a lot of work but to find the correct sms 0center number your Os understands and writing it is really a pain
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 1,724
