Why are my speakers emitting static?
The speakers of my laptop begin to emit a good amount of static whenever I play the volume at a moderate-high volume. When I use headphones, the audio is fine so it must be the speakers.
Esta é uma boa pergunta?
This problem is almost definitely a hardware issue, however you can try reinstalling the sound card driver found on Gateway's website: http://www.gateway.com/gw/en/US/content/.... If this doesn't work, you need to consider replacing the speakers or seeing if your laptop is still under the factory warranty.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 18
Ao todo: 336
