Ir para o conteúdo principal
Why can't I turn my iPod on?
Hi,I have had my purple Ipod nano 5th generation less than a year and I managed to break it. It won't turn on, even if I try to restart it. If I plug it in to charge, it will charge but when I unplug it, it won't turn on! Please help me! Thank You a lot.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Thanks for the help! I hadn't plugged it in in a while but I just did and now it works!! But thank you soo soo much for the help!
por
Adicionar um comentário
1 resposta
Solução escolhida
Sounds like a dead or bad battery. Probably not holding a charge, that is why when you unplug your Nano it stay dead you will need one of these iPod nano (5th Gen) Battery and how to do it is here iPod Nano 5th Generation Battery Replacement good luck and let us know if you have any issues after that.
Imagem de Replace a battery compatible with the fifth generation iPod nano model A1320. 250 mAh.
Produto
$13.99
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Elli será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Ao todo: 1,584
