Ir para o conteúdo principal
iPhone 6 Might have died? Please help.
I replaced my iPhone 6 battery in February I made sure I was careful with everything but one day last week it died. While it was charging it just shut off. But it wasn't warm while charging(usually is) So I tried everything just in case it just needed a reboot but no luck. I opened it and it had a bad smell I took out the battery just in case and disposed of it properly. Any idea what happened? Not sure if it was the logic board or battery please help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
The smell thing has me concerned. The board can damage chips and cause a weird smell but so can the battery. Cheap replacement batteries are available on iFixits websites. Here is the link: Substituição da Bateria do iPhone 6
Unless you hit a chip on the board, I doubt it is anything more serious then just a defective battery. Try to install a new battery (new original batteries are the best) and that should get your iPhone back up to normal in no time at all.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Prozak será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 62
