Ir para o conteúdo principal
Informações de reparo e guias de desmontagem para laptops fabricados pela Haier.
Some keys of keyboard NOT Working?
Some keys of keyboard NOT Working ??Like N,space,ALT,B,C.ENTER key .How can i repair..If it cannot be repaired and need to changed keyboard of my haier laptop ?Which keyboard model can fit into this laptop.Thanks
Esta é uma boa pergunta?
Pontuação 14
15 comentários
faraz0920 what model is your Haier Laptop
por
Haier YB11 PM Nawaz Shareef
por
Hello,
We have an laptop y 11c ,its keyboard has been stop functioning because of few drops of water have spilled on it, i want to change its keyboard so that it could function like earliar..
por
i have new hair laptop of prime minister and some keys of keyboard not working now what i do bro
por
If it's new, take it back to where you bought it.
por
Exibir mais 10 comentários
Adicionar um comentário
4 respostas
Solução escolhida
I don't know this make of laptop, but for most, swapping the keyboard is fairly straightforward. You may have to remove a bezel between the keyboard and the hinge to gain access to the required screws, or you may have to remove one or more screws from the back, or indeed the keyboard may just clip in place. Then you just need to be a bit careful in releasing the ribbon or ribbons connecting the keyboard to the motherboard. You probably wouldn't be able to fix the troublesome keys in your existing keyboard.
You will need a replacement keyboard for the exact same model, and make sure it's the right language, but hopefully you can find one on eBay.
Esta resposta foi útil?
Pontuação 2
Pergunta mais útil
Guys, for Haier y11c, the best option is to disable the keyboard and use an external one. The best method I’d recommend is to disable the keyboard hardware by opening up the laptop and detaching the ribbon cable. This way you will not have to put up with any funky software. You could try disabling it through a software called KeyTweak.
Other than that, replacing it might cost you around 4-5k PKR since the keyboard is chiclet-style and you will have to replace the whole panel. This is just not worth it.
Pontuação 3
1 comentário:
In my case, the key tweak is working very well. At least there's no need for an external keyboard now, although my first two rows are dead. I have replaced some necessary keys and also touch keyboard as well helping me out.
por
The keyboard is faulty and needs to be replaced to solve it.
Pontuação 1
Visit following link .
https://youtu.be/AZS4osYJ_C8
Pontuação 1
1 comentário:
Irrevent solution.
por
Adicionar a sua resposta
faraz0920 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 43
Ao todo: 17,320
