Ir para o conteúdo principal
Lançado em 1º de maio de 2015 pela LG. Também pode ser identificado pelo modelo LS770.
Call Management has stopped
I can make phone calls but when someone calls me it pops up unfortunately call management has stopped? How do i fix this without having to do a factory reset?
Esta é uma boa pergunta?
Pontuação 11
9 comentários
unfortunately, the process com.android.phone has stopped
por Compartilhar
I have a LG G3 and I can't find app ATT anywhere not even in my settings what should I do??
por Compartilhar
I'm having a problem wit my style lo 2 phone i can call out but wen i get a call it goes to voice mail
por Compartilhar
I'm having a problem with my LG style 2i cant call out no one can call me its says call manage stoped HEKP PLEASE
por Compartilhar
Facing the same problem but can't find the drivemode on my phone
por Compartilhar
Exibir mais 4 comentários
Adicionar um comentário
8 respostas
Pergunta mais útil
I had the same issue this morning on my LG Phoenix 3. I called AT&T customer support. The person I spoke with said they had JUST received notification about how to fix the issue... It worked for me:
1. Go to your Apps; Find ATT DriveMode; Uninstall updates
2. In settings, go to Apps, DriveMode, and Disable app.
Hope that helps!
Esta resposta foi útil?
Pontuação 19
24 comentários:
This fixed my phone! Thank you so much!
por Compartilhar
This worked right away. I find it amusing that AT&T bloatware caused the issue.
por Compartilhar
I wasn't getting any calls this morning... Everything went to voicemail and phone said Call Management has stopped. I followed these instructions "Find DriveMode, Uninstall updates, and disable app" and now I get phone calls fine. This is on an LG K10. This is ridiculous that they would auto install update that makes phone stop receiving phone calls.
por Compartilhar
Thanks, didn't have ATT Drive Mode, but did have Drive Mode in my apps. Force closed, Disabled (Set to factory version? Yes) and now I'm getting calls on my LG X venture
por Compartilhar
Just tried this and so far my phone is ringing again. Ridiculous updates....
por Compartilhar
Exibir mais 19 comentários
Just go to settings-apps and notification-default app-phone app- change to contacts(system).
Pontuação 5
6 comentários:
I really appreciate you. Its work me. Thank you so much dear
por Compartilhar
Awesome, it works on my LG V20! Thanks a lot!
por Compartilhar
@Ayodele Segun hello dear am facing the same problem on my LG g5 but I don't know where to locate drive mode on my phone
por Compartilhar
@cheey2003 hi dear am facing the same problem on my LG g5 but I don't know where to find drive mode please help me how did you solve yours
por Compartilhar
@Issah Iddrisu As my LG V20 is not from AT&T, there is no ATT DriveMode app in my phone. The issue happened when TrueCaller app was set as the default Phone app - thus changing it to the stock Contacts (System) app resolved the issue for me.
por Compartilhar
Exibir mais 1 comentário
Go to the phone app in settings, then select clear cache. If you can, uninstall the app then reinstall it on the play store.
Pontuação 0
6 comentários:
i tried that and it didnt work
por Compartilhar
Is there a call management app? If so, do the same.
por Compartilhar
Call apps was my first problem re installed it or first I stopped it then restarted it in safe mode just like screen overlay problem kinda but in safe mode it was hidden elsewhere so I could not find it so I just stopped it in apps I'm trying that outa safe mode then trying in safe mode resetting all app preferences might work if you just keep doing it maybe ?I'll try your way this lg is my first but I'm thinking boost is a pretty sorry server I've been straitalk Trac phone net ten call Trac phone they own them all fixem quickly straitalk lol was losing it at start tried sending signal across ocean no towers poor peps no speak English I called Trac phone boom fixed might think some don't know that because at night your talking Philippines lol they was hired and trained poorly leave you on net lol
por Compartilhar
Quick memo was another bad one on call apps contact trying to reload now voice mail I lost a bunch of time kill and reload is only way or back up till it works heck I have a 32 bit card and 16 gigs on phone kiss it goodbye back up from memory sd it works on mine reinstalling call apps contact it won't let me load any more 1 did but it stinks phone app call log monitor to confusing still said call management stops to might work for you it's a screwy app to figure but I might be not hitting all the tricks yet I'll let you all know k call apps contacts just keeps going out everybtimeb
por Compartilhar
Just disable ATTdrivemode. Worked for almost everyone including me.
por Compartilhar
click on the icon, drag it to the top of the screen, there will be boxes that you can disable and uninstall updates. once doing that your phone will accept calls. hope this helps !
Pontuação 0
1 comentário:
Have a lg k8 2017 have no att drive mode at all installed still wont let me call any1 please help
por Compartilhar
I had the same problem. but after uninstalling the True Caller App everything was OK.
Pontuação 0
1 comentário:
Wow!!!.. Joseph it works thanks very much
por Compartilhar
For LG v30, …
  • go to settings , then locate apps
  • inside apps, check the burger button tip right ,click to reveal hidden options
  • click on configure apps
  • click on contacts
  • go back one step and click on app permissions , then check contacts
  • done
Pontuação 0
I had de same problem today but after uninstalling truecaller I start receiving calls
Pontuação 0
1 comentário:
How do i do the same thing
por Compartilhar
How do i fix my text now to stop saying call management has stop in return it to service
Pontuação 0
2 comentários:
I have some problem
por Compartilhar
How do I open my call management
por Compartilhar
Adicionar a sua resposta
Katrina Chetney será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 36
Ao todo: 38,892
