sombody help me with my 4s
Why is my screen all white i can go to my apps but i cant see nothing
Esta é uma boa pergunta?
Probably the screen needing to be replaced, was the screen cracked or went bad after drop?
Or maybe liquid damage and that happened afterwards?
In case it is the screen you can fix it yourself by using this guide here and the link to buy the part:
Guide for screen replacement:
Where to buy part from iFixit store:
Esta resposta foi útil?
This is whats known as the white screen of death. Attempt a reset by holding the power and home button down for 10 seconds to do a reboot The apple logo should then appear on the screen if everything worked correctly. If not you may need to attempt a full restore.
Hope this helps.
Stephen
CPR Roseville
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 68
