How to fix the cable rewinder
Hello,
The cable does not rewind completely when i press the botton. I would like to know how to fix this.
Thank you
Esta é uma boa pergunta?
Hello,
Thank you
@den23 , Den, Rewind spring may of detached from it's retainer. Use the link below(Philips Marathon Vacuum FC9202) service manual, to aid in disassembly of your vacuum to check/replace/repair the auto rewind spring/mechanism. Pg. 6 show's the mechanism in detail. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 39
Ao todo: 3,865
