Ir para o conteúdo principal
Released October 13, 2016, the PlayStation VR is Sony's first virtual reality headset designed to work with the PlayStation 4 gaming console.
42 Perguntas Visualizar todos
replacement for PSVR Silicon Guard
Where can i get a replacement silicon eye guard? lost previous.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Okay you can check there there is good and well information in the Sony Button. If you want the get a replacement of Silicon guard then you can ask our technical department support because they’ll provide you better solution. http://playstation.gamesupportonline.com...
Esta resposta foi útil?
Pontuação 1
joeeoj2000 , Did a good search for replacement PSVR Silicon Guard with no luck. Forums I had read recommended that you contact Sony at the link below to inquire about part availability. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.playstation.com/en-au/get-he...
Pontuação 0
Adicionar a sua resposta
joeeoj2000 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,703
