Ir para o conteúdo principal
O Dyson AM07 é um ventilador de torre sem pás lançado em 2014. O AM07 utiliza a tecnologia "Air Multiplier" para criar um fluxo de ar suave sem o uso de pás visíveis.
fan not oscillating back and forth
What's wrong and how do I fix it?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
I have the problem too, it is not oscillating.
por Compartilhar
Adicionar um comentário
2 respostas
Solução escolhida
mkoch, If it is new, did you remove the tape, from the lower base body split section, if not remove before turning on any more or damage to internal gear could occur. Recheck that the fan is still assembled correctly and locked in correct position. Install new batteries in remote and try. If all looks good and still under warranty return for repair/replacement/refund as there may internal damage to oscillating gear. See below links, your manual and Dyson support site.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.manualslib.com/manual/888752...
https://www.dyson.com/support/am02/am02-...
Esta resposta foi útil?
Pontuação 7
2 comentários:
So simple, duh, I forgot the tape. But it doesn’t show that in the setup instructions.
por Compartilhar
I need help in opening the remote. I've had three people look @ this remote. Pls help!!!!!!!!!!!!
por Compartilhar
It would be more helpful if the tape that has to be removed was an obviously different colour rather than white the same as the oscilating plinth - ie ... make it idiot proof - it took me a while to work it out as well lol
Pontuação 0
Adicionar a sua resposta
mkoch será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 92
Ao todo: 51,108
