Ir para o conteúdo principal
7.9 inch android tablet manufactured by Acer in 2013.
32 Perguntas Visualizar todos
help needed keeps factory reseting
my acer iconia a1-810 will not turn on into the normal home screen it stays in the "android system recovery' and every time i try to "reboot system now" it restarts and says "erasing" for a good 20 seconds. The tablet is not even 3 years old a good tablet. please help
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Evidently junk, I will never buy Acer again.
por
Adicionar um comentário
1 resposta
Solução escolhida
Try a hard reset by disconnecting the battery for a few minutes . This guide will help you get in and shows how to disconnect the battery.
Acer Iconia A1-810 Battery Replacement
If this brings no joy try wiping the cache partition .this should help with that
http://www.urtech.ca/2015/09/solved-what...
Hope this helps
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
harry bailey será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,081
