Ir para o conteúdo principal
Where can I find a replacement USB charging circuit board for UE Boom?
Due to corrosion, I need to replace the USB port, along with the circuit board attached to it from my UE Boom. I can't seem to find the part anywhere. There are plenty of numbers on the circuit board, but they all seem to be random. I was hoping someone could either tell me where I can find the part, or give me an alternative solution. I'm trying to avoid buying an already broken donor speaker for the part. The board does say that it is manufactured by Logitech.
Here are the numbers:
TP503
TP502
TP501
3613C
E153302
94V-0
USB_1417-002
CN501
Esta é uma boa pergunta?
Pontuação 2
5 comentários
I need to buy this item but i don’t know how
por
Not charging properly
por
How to purchase charging circuit board model s-00122
por
Anyone just added another port to charge the battery? Then connect direct to the battery
por
@lyndonjc
Doing that may be a bit dangerous because you would be bypassing the battery management circuits which prevent the battery from being overheated or or overcharged whilst charging
por
Adicionar um comentário
3 respostas
Pergunta mais útil
Hi,
There isn't a lot of options out there for this replacement part. I only found two options actually:
1. purchase (the port only) from eBay and desolder the old port from the existing board and connector and solder the new port on.
Link below -
http://www.ebay.com/itm/3x-Lot-Micro-USB...
2. According to UE you can call their customer service (1-646-454-3200) and order replacement parts directly from the company. They are Mon-Fri: 6am - 6pm (PST).
Good Luck.
Esta resposta foi útil?
Pontuação 4
3 comentários:
Thank you for your help. I've seen that piece on eBay before, but I'm pretty sure that I need the board along with the ribbon cable that goes with it. I'll give UE a call and see if they can send one out to me. Again, thank you.
por
any other link where i can get this board please
por
I have been on the phone with Logitech’s parts department for about 30 minutes. What a joke. They dont have parts but I can buy a new one and they will give me 20% off. I told them no I would go with a better brand next time.
Pontuação 1
The charging boards on UE Booms are nearly impossible to find. One flaw of these great speakers is that, sometimes if you leave it on the charger too long, it will overheat and melt the port and board. So far I've had this happen to 3 of them.
So used boards or donor speakers don't usually have these. It's about the only thing that goes wrong with them. I've been looking for a year and can't find one. I've now got 4 useless UE Boom 2 speakers.
Pontuação 0
Adicionar a sua resposta
Samuel Abraham será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 37
Duração total: 8,070
