My phone keeps flicker yellow on n off
My gelesy s5 keeps flicking in n out yellow how do i fix it
Esta é uma boa pergunta?
Usually this happens right after the phone is dropped. If it is then you will need to get the screen replaced.
Esta resposta foi útil?
*Hello, if you have an Android device, and if you enabled Developer Mode and selected an option that gives you a visual screen update flash, this is why. Please turn off the "Show Screen Updates" and/or "Show GPU view updates" and/or "**Show hardware Layers updates"
*Please note, these instructions only apply to Android Devices, if you do not have an Android device, or if your phone has visible damage, the screen's pixels may be disfunctional.
My phone did the same thing and turning off auto-brightness fixed mine.
If you continue to have people give their opinions on fixing your phone it would help tremendously if you can understand what that person is saying, I can't understand what the &&^& these @%^$$@$# are saying, get a person that doesn't sound like they just learned English as a 4th grade refugee!
Stop with censorship, people know what I meant when you add these $%^&**^^ crap to hide my potty mouth...you &&^&^$ @%^$$@$#!!!
Mt phone is half yellow and it glitching then turns black and the top half of phone is normal
Hi Mackenzie,
That sort of behavior is almost always a result of a damaged or defective LCD screen. To fix the problem you'll have to replace it. iFixit has a guide showing you step by step how to replace the screen and can even sell you the part you need if you want!
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 37
Duração total: 12,982
