Ir para o conteúdo principal
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
Phone Not Turning On
My phone got off automatically! For some time only samsung logo was seen after that there is nothing! I tried changing battery bt didnt work! There is nothing while charging except phone gets heat up.! Did i lost it ! please help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Have you tried getting to the boot menu of the phone by holding the Volume up button and the power at the same time.If the boot menu is working try to do hard reset or try to restore it to its original firmware via kies.
-Hard Reset
1. Hold the Volume Down button
2. Press and release the Power button
3. A menu will then appears
4. Select Clear Storage by pressing the Volume Down button
5. Press and release the Power button
6 Select Volume Up for YES and Volume Down for NO
-Guide on restoring original firmware with kies
http://www.samsung.com/ca/support/skp/fa...
Esta resposta foi útil?
Pontuação 0
2 comentários:
Already tried
por
Phone is not starting!!!! So unable to hard reset it.
por
Adicionar a sua resposta
Kashif Abdullah será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 92
