JBL Xtreme Speaker Busted
My JBL Xtreme speaker busted I guess from playing to loud of course. Any way to fix it?
Esta é uma boa pergunta?
@travisanthony3,Travis Anthony, I do not own this device. You can try a reset, while the device is powered on, press and hold the ‘Connect’ and ‘Volume Up’ buttons simultaneously for 5 seconds to factory reset the device. Did not help, you will then have to proceed to disassemble the speaker to locate/test/bad components/ loose connections/ ripped speakers, etc.. Below are links to show disassembly and 2nd link is to trouble shooting JBL XTREME.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Esta resposta foi útil?
Can it go Louder
I had same issue with distorted busted sound. I did the reset and now it won't turn on at all and my speaker no longer works.
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 52
Duração total: 12,844
2 comentários
What does "busted" mean? Is the speaker cone torn?
por Russ Walden
I mean I guess! Just every beat sounds horrible now! Like the vibration sounds badd
por Travis Anthony
