Ir para o conteúdo principal
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Perguntas Visualizar todos
Only one earphone works / Seulement 1 écouteur qui fonctionne
I already looked trough the question but my problem doesn't seems to be reported by someone else.
If I put the earphones all the way in the jack only one earphone works (the left one) but if on 3/4 both works...
Using the bose soundsport for android but I don't have that problem on my ipod touch...
Any clue?
Regards
J'ai déjà regardé au travers des questions sur le forum et je ne trouve rien de ressemblant.
Quand je met mes écouteurs dans la prise jack j'ai qu'un seul écouteur qui fonctionne (le gauche) par contre si j'enfonce au 3/4 les deux fonctionnent...
J'utilise les bose soundsport pour Android mais j'ai pas ce soucis sur mon ipod touch...
Bien à vous
Update (04/04/2017)
Problem isn't that... I think I will have to change the jack
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Avez-vous essayé d'autres écouteurs?
por
Je pense avoir trouvé le soucis.
Mes écouteurs sont en 4poles et l'ipod en 3poles :)
por
Adicionar um comentário
4 respostas
Solução escolhida
@papyours this sound like a bad headphone jack. I'd replace the audio jack. Follow this guide. The part is available at multiple places, depending on your geographic location.
Esta resposta foi útil?
Pontuação 3
Have you tried a different set of earbuds?
It really sounds like one of your ear buds is broken so try a different pair or a pair of headphones.
Hope this Helps!
Pontuação 1
1 comentário:
Yes I just did with a 3 pole earphones but still only the left is working ...
por
There is issue with setting of sound. No issue with hardware. Do one thing reset all audio profile to default.
Recheck internal sound setting for jack as it is working fine with ipod touch.
Pontuação 0
3 comentários:
Think I found the problem coming from the jack my earphones are trrs and the ipod is trs :)
por
Just tried to reset and nothing
same problem with a three poles earphone
por
Malik problem occur with jack or with iphone ipod ?
por
I think so too... Seems like I damaged the flat cable while changing the back case... :(
I'm from europe but Ifixit on Facebook told me about powerbookmedic and they are very cheap oO
Pontuação 0
Adicionar a sua resposta
Malik será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 259
