Ir para o conteúdo principal
Um tablet desenvolvido pela HP em 2011 que roda a plataforma webOS. Possui uma tela de 9,7" e está disponível em 16 ou 32 GB. O reparo é simples, mas requer tempo e persistência.
Display problem in middle of display
My display has developed a 2" bar across the middle that is all garbled or fuzzy meaning you can't read or see what is supposed to be there. Otherwise the unit works well. Is there a way to fix this problem? Thanks in advance for any help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
likely the pins in your LCD connector are likely built up with dirt. Open the device, remove the LCD connector. use a toothbrush and 99%isopropyl to scrub at bot the gold traces at the end of the flex, and inside the female connector of the board. Air dry for 10 minutes, and reconnect.
This SHOULD Fix your issue.
If it does not, either the flex is damaged, or the connector on the mother board is damaged.
-if the flex is damaged, replace the LCD
-if the connector is damaged, remove the connector, and solder a new one onto the board. (This last step is a more difficult procedure, and without SMT Soldering experience, i would suggest taking it to a professional.)
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Peter Mather será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Ao todo: 333
