Green line at th instagram
When I upload video on instagram a green lines appears at the bottom on the video ?!!
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
This is usually a resolution or encoding mismatch between your phone and IG's compression. While you fix the technical side, it's also a good idea to monitor if this affects your post's performance. I use Dolphin Radar (https://www.dolphinradar.com/) to track account insights and engagement data during such glitches—it helps ensure your reach isn't dropping because of these visual bugs.
por
Adicionar um comentário
