Ir para o conteúdo principal
O Sony Xperia M4 Aqua foi lançado em junho de 2015. Com uma tela de 5,0 polegadas, ele operava com o sistema operacional Android v5.0.1. O Sony Xperia M4 Aqua possui armazenamento interno de 8 GB, 2 GB de RAM ou 16 GB (E2306). Ele tem uma câmera principal de 13 MP e uma câmera secundária de 5 MP. Este celular possui uma bateria de íons de lítio de 2400 mAh não removível.
Phone stopped powering on... maybe a possible fix!
Okay... so i had a m4 aqua with no screen output, but it responds(let's refer as first phone). Recently i got a cheap m4 aqua that only needed to swap the battery so i did it and it worked for some time( let's refer as phone 2). I don't know why the phone 2 is not turning on anymore(something with power delivery i'm guessing). Now that i opened both phones to check differences i saw that there are some parts missing from the first phone that are on second(pics attached) maybe it's possible to somehow combine 2 into 1 and make 1 functional phone?
Imagem
Imagem
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
on phone 1 there is one missing LCD Filter part, you dont need to take component on phone two and resolder it on phone one. just do the jumper to makes LCD on phone 1 works again..
i hope this helps
Esta resposta foi útil?
Pontuação 0
2 comentários:
So you are saying it's possible? How to do the jumper thingy?
por
i have done many cases like that.. just see on my instagram page @masterdogen_qualityrepair
por
I have also same problem.. After pressing the power key.. Sony logo come then release the power key.. Mobile get shut down
Pontuação 0
Adicionar a sua resposta
igors riekstins será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 18
Ao todo: 1,627
