Model HL67A750A1FXZA picture disappears
After a few minutes of use, the picture disappears. Sometimes after 5 seconds or so, it will come back on. Sometimes not. We have to turn tv off then on again to regain picture
Esta é uma boa pergunta?
@whitewater lets start off by checking for Samsung suggest:
and here is the flowchart
Check to see if your LED's display any error code
To access the service mode follow this:
The number 2 DDP3021 menu is where you want to go. here you can check #8 to see if your DMD board is working properly
Besides all that you do want to make sure that you do not have any fan (overheating), heatsink or capacitor issue. Check for any leaking bulging or otherwise failed capacitors. Post some images of your boards with your question. that will allow us to see what you see. For that use this guide
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 253
7 comentários
@whitewater when you turn the TV off and back on, will it then stay on or continue its cycle? when the picture disappears can you still get the Menu to display?
por oldturkey03
It will continue the cycle
por Craig
I'll check the menu the next time
por Craig
Yes. Tv menu will pull up when picture is out
por Craig
@whitewater does that happen on all inputs? Check with different input sources. Do you keep the sound or does that turn off as well? Do you get any error code flashing from your power led etc.? are you fans working? Have you taken the back off to check for obvious damage? Clean the boards and fans from any excessive dust.Since you do maintain the menu I suspect issues with the main (video) board.
por oldturkey03
Exibir mais 2 comentários
