Camera not working after screen assembly replacement?
I've got a A1502 that I just replaced the screen on (replaced the entire assembly) and now the camera is not working. I'm almost 100% certain that I didn't put any strain on the cable. It flashes green when I try to use it in FaceTime or photo booth. FaceTime just stays black and photo booth has a constant loading circle.
The camera was not tested prior to service due to the LCD going completely out.
Any ideas? Is it possible that it's the logic board or is it mostly likely a defected assembly or other issue? The seller is willing to exchange it for another but I want to make sure I'm not wasting my time! If any other info (pics, etc) is needed please let me know!
Esta é uma boa pergunta?
1 comentário
Hi, I faced a similar problem after assembly replacement for A1502, I got it done from technician (not service centre who also sold me the same) , camera did work for first time after reboot, for around 3-4 days, then ended up showing no camera connected for another 2-3 days, then again worked few days later. Right now it has again stopped to show up on system report and shows error" not connected to camera "while on apps.. Apparently I visited the technician again he cheked for the assembly in his system and i
Camera worked without fail for several times after multiple restarts also. Probably the assembly is not faulty, but what for I am facing the issue...how can I fix it? The tech guy says my motherboard is screwed up or something...please help me...
por Shashwat
