Ir para o conteúdo principal
Guias de reparo, suporte e desmontagem de filmadoras projetadas pela Flip Video.
Change date and or reset unit
I have one of the earliest flip camcorders. It works great, however when inserting new batteries recently, the change date screen came up.
I inadvertently closed the screen before entering current info.
Mfg. Pure Digital Technologies
Model: F160B
Holding power button in for 10 seconds does not work
No tripod mount, thus no reset hole
Holding the power button on while pushing the up arrow does not work
Removing batteries for any amount of time does not work.
Nothing on the internet for a F160B or just a flip 60 seems to work.
Date is stuck in 2006
This happened long ago, I fixed it, but for the life of me I cannot remember how I did it
Thanking you in advance for any help you can provide
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Hi there, I have the same problem now. Is there any chance you remember how you fixed this? Thanks so much
por
Adicionar um comentário
2 respostas
Solução escolhida
So I'm pulling the batteries, and will let it sit for a very long while. Hopefully any onboard batterey will discharge. We'll see.
Hawk
Esta resposta foi útil?
Pontuação 1
1 comentário:
mate... just dug out my old minoHD date wont pass 2020..
por
Pergunta mais útil
Try this:
1) Power off the camera
2) Turn on the camera
3) When the logo appears, hold the record button, and "Set Language" should appear
This should allow you to go through the original configuration routine.
Pontuação 1
2 comentários:
Didn't work. Sorry I didn't include this one in my description. I can say that everything on the internet regarding this has been tried, at least that I have found after hours of research. Thank you for your reply though!
por
I think this is the original flip, it even has the "DVD retail processing port" on top!
por
Adicionar a sua resposta
Petrohawk será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 18
Ao todo: 1,267
