Ir para o conteúdo principal
ac is working only sometimes
yaris ac is working only sometimes
the problem started before 2 months , and changed control valve of ac compressor , but still problem is same
when ac button on , ac fan roatates and compressor works , but no cool
sometimes when ac switch on , cool also
Esta é uma boa pergunta?
Pontuação 2
1 comentário:
Dear i also face same situation i don't know what happens sometime its working good but after sometime ac leave the working
por
Adicionar um comentário
1 resposta
It sounds like you have low refrigerant levels. At lot of times low refrigerant manifests as intermittent cooling. Here are general instructions for recharging an AC: https://www.walmart.com/ideas/auto-maint....
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
msajidvp será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 23
Ao todo: 2,086
