What does this mean? printer message: change unable 51 see user guide
what does this mean? change unable 51, See troubleshooting and routine maintenance
chapter in User's Guide
Esta é uma boa pergunta?
Denise Greer use a small amount of warm water on a cotton swab until and clean the contacts on the cartridges, as well as on the printer as well. They are reasonable clean when no ink comes off on the swab.
If any cartridge is low, empty, leaking or bulging replace them. After cleaning turn off the printer, unplug it for a few minutes. Plug it back it and wait for the insert cartridges message then insert the cartridges and check to see if the problem is resolved. If it has not been resolved it could be a failed print head.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 10
Duração total: 1,414
1 comentário
Denise Greer does it say "change unable 51" or "print unable 51"? Error 51 and error 32 ,unable to print, unable to clean, and unable 36, are all print head errors.
por oldturkey03
