Ir para o conteúdo principal
O HP Probook 4530s faz parte de uma linha de notebooks empresariais fabricados pela Hewlett-Packard (HP). Ele é da Série S (série padrão), composta por telas equipadas com processadores Intel.
Windows Boots Up But Not BIOS
HP Probook 4530s
Windows 10 Home 64 bit, Insider Preview 15063 (rs2_release)
Core i3 2310M
8GB RAM
120 SSD for windows, 320 HDD
BIOS F.61
Windows boots up fine everytime. Very long time since i went into bios settings, i wanted to see if boot from usb option was on, and on startup when i press esc key or any function keys to get into bios settings, the screen goes black, hard disk light turns on and remains on, caps lock light starts blinking, i don't have num lk key.
I reinstalled bios and nothing changed. My battery is weak, if that matters, a warning is shown on boot up.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
HI:
I think you have a UEFI (bios) not the same as the bios is on the motherboard I a chip and the UEFI is on the hard drive but built to operate like.
watch this video and it will show you some answers,
Press F2 for first screen then ESC
https://www.youtube.com/watch?v=cp7fhjGO...
Good luck
Esta resposta foi útil?
Pontuação 0
3 comentários:
No I checked, I have legacy bios. Even if I do have UEFI its menu should open.
por
Yes the motherboard has a bios but to get to the program to change the settings is on your hard drive. I went to the machine's web page and looked plus I sent you a video link of the same machine being booted as I described.
Yes the menu should come up. I hope you are being fast enough to press your keys. With power down then boot start your key strokes immediately.
If you have reinstalled the bios it just could be how fast you try...
Good Luck
por
Pressing the keys is what brings up the black screen.
And like in the video i could get into the bios settings before.
por
Adicionar a sua resposta
Jamal Tariq será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 19
Ao todo: 3,670
