Why does it stop on starting windows for even a day?
i have a dell lat E6500, after putting in another hard disk, it opens but it eventually stops on starting windows i dont know why and what to do.
Esta é uma boa pergunta?
@mm2 , matutu moses , Just a thought: If the hard drive has not worked since you put it in and you do hear it running, perhaps the OS did not install properly and you may want to try a reinstalling the OS. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 82
3 comentários
Hi,
What OS is installed?
Does it start OK in 'safe mode'?
por jayeff
Are you saying you have 2 hard drives currently in the same laptop?
por S W
More details, Please. Did you replace or add a hard drive. Is the hard drive identified in BIOS (hit F2 on start up when you seen the Dell logo)? What version Operating System are you using, is it Home, Professional, 32 bit or 64 bit? Are there any error messages?
por DrGlowire
