Ir para o conteúdo principal
Apple Watch Series 2, announced September 7th, 2016 and released September 16 2016.
20 Perguntas Visualizar todos
Ion screen vs Sapphire screen?
Can I replace the ion screen on an apple series 2 iwatch with the sapphire version? The original watch had the ion screen on it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
You may want to rethink this!
While it's technically possible you will loose the water tightness a factory installed screen has. You will also have less visibility to the screen as Sapphire is not as transparent as the Ion glass screen.
Lastly, while the Ion glass can scratch a bit more easily, the Sapphire can fracture if struct with a sharp object (brittle) unlike the Ion glass. Here's a more:
I would stick with the Ion glass my self if you need to replace it otherwise leave it alone.
Update (07/07/2017)
Here's the newest version of Gorilla glass: Corning - Gorilla Glass SR and here's another writeup from Engadget: Corning's latest Gorilla Glass will make wearables tougher - Gorilla Glass SR
With this announcement the need for Sapphire for coverglass in either phones or watches is now almost pointless as the differences is so little!
Esta resposta foi útil?
Pontuação 1
if you own a Samsung smartwatch then is important to use Sapphire for coverglass.
Pontuação 0
Adicionar a sua resposta
Casey Bellefleur será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 1,398
