replace the swiffer vac circuit board?
can you buy or repair the swiffer vac control board?
Esta é uma boa pergunta?
@uncledave11 , Dave, I did not find any one selling the replacement board. If you or a friend have some knowledge of using a DVOM and some familiarity with components on a board, capacitors, resistors and diodes you can test and some times visually see defect and replace parts. Below 1st link will get you inside the vacuum to the board I believe and the other 2 links are some tutorials on how to test and visual for failed components. Good luck.
Swiffer SweeperVac Battery Replacement (PG3000)
Esta resposta foi útil?
Is silver or cardboard side placed on the battery? Step 3 - photo look like silver side on battery. Step 5 - photo, unable to tell
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 424
