Ir para o conteúdo principal
Xbox One Stereo Headset, número do modelo B00IAVDQCK. Lançado em março de 2014, compatível com o Microsoft Xbox One. O headset inclui almofadas de tecido circumaurais, microfone boom unidirecional e um adaptador de headset removível com controles de volume e de microfone.
Cable Plug-in Portion Destroyed
The cable that attaches to my Stereo Headset Adapter was chewed off by my dog. Besides that, the adapter itself, the headset, microphone are undamaged. Is there anyway to replace ONLY the cord portion of the device?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Although this guide doesn't show opening the cable side of the headset, the practice is the same.
Inside the cable portion of the head set the cable should be connected with some solder, simply heat the solder with a soldering iron and the old cable should come right off, and simply replace with a new one.
Or
you have just clip the cable above the damaged area and splice the cable with a new one, and cover with some heat shrink tubing or electrical tape, which means you don't have to open the headphone, but it's a bit ghetto.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
snow.surfer22 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 500
