Automatically shutdow/ auto tripped off every I turn on my laptop
Please give me you further advice before i go to technicians...if i can do this at home i will
Esta é uma boa pergunta?
It could be a problem with static discharge, if so do the following.
1. Disconnect the power cord
2. Remove the battery
3. Hold down the power button for 30 seconds, then release for 30 sec and then hold down for another 30sec
4. Plug in power; replace battery and power on laptop.
If this causes no Joy try this.
Remove memory and reinstall one stick at a time, if there are more than 1 DIMM of RAM, try each stick in each slot one at a time to see if the memory is ok and to determine if one of the memory slots is bad.
Hope this helps
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 228
1 comentário
Hi,
What has 'auto tripped off', the wall power outlet safety switch?
Or do you mean the laptop shuts down and there is no indication of power being connected etc but the wall outlet is OK?
Give us more information to get more relevant advice!
How far does the laptop turn on before it shuts down?
Does it start to boot into Windows at all,if not are there any error beeps or messages on the screen? If it does start to boot into Windows does it get to the desktop at all etc etc.?
Does it do this on when on battery only or if the charger is connected?
por jayeff
