Ir para o conteúdo principal
In 2012, Sony Entertainment announced that the company would be releasing a new version of its 2006 Playstation 3 console. The new console is call the Playstation 3 Super Slim and is identified by the model number, CECH-4000. The PlayStation 3 Super Slim (CECH400x) is the third version of the PS3 video game console produced by Sony Computer Entertainment. It was released October 25, 2012.
211 Perguntas Visualizar todos
Stuck on the update loop!#8002F1F9
The system update is stopped when it reaches 60% and it shows the error code#8002F1F9.
When I restarts the system, the system update starts from the beginning directly and repeats the same problem. What should I do? Please answer me fast...
Esta é uma boa pergunta?
Pontuação 23
11 comentários
I have this problem too, would replacing the hard drive solve it
por
I updated my ps3 and it showed me elan error code then i new what to de then it showed the same thing
=== Update (01/23/2020) ===
I am stuck at 49 and it dosent complet it and it appeared an error code 8002F1F9
por
HOW i reset muy PS3 from code 8002f1f9
por
When I restart it it keeps giving me a code thing
por
Replacing the CMOS battery fixed mine. Thanks for the advice!
por
Exibir mais 6 comentários
Adicionar um comentário
6 respostas
Solução escolhida
I had this problem. When I took apart the PS3 to clean the dust, replace the thermal paste and hard drive, I started getting this error when trying to update.
What fixed it was replacing the CMOS battery (watch battery on motherboard). From a suggestion from this guy. The CMOS battery change did the trick.
I am getting error code (8002F147) on my PS3
Esta resposta foi útil?
Pontuação 9
5 comentários:
How do you get the cover off to get to the mother board x
por
I have the same issue , stuck at 99%, then reboots. I have tried everything accept the wifi, bluetooth module., I formatted fat32 on both hdd and USB ran in safe mode, option 6, and ran untill 99%. I am going to investigate he wifi module though, what happened with my unit is I updated the unit and the power went off. Eversince I can't install the update. Any new help please??
por
You can try to replace the CMOS battery inside your PS3. This would involve you taking apart your PS3 though. So that depends on how confident you are with taking apart your PS3
por
Error code 8002F147 is caused by your console not being able to properly read the media that the update PUP file is on.
Source:
https://www.psdevwiki.com/ps3/Error_Code...
por
I actually got this error after a combined operation of dust cleaning, changing cooling paste and installing a new SSD plus a new cmos battery before trying to update. I got this loop and after reinstalling the original HDD it would not boot either.
After reopening the console
I found that the ribbon cable to the wireless module was not properly inserted during reassemby. After just reinserting that cable the update did finish and the ps3 worked as normal again.
So probably a bad wireless card in my case, but thankfully it didnt need to be replaced, just reconnected.
por
Several possibilities:
1) Bad bluetooth/WiFi card - this is easy to replace.
2) Bad nor chip - this requires soldering
3) Bad Hard drive - this is easy to replace.
4) Try downloading the update to a USB stick and update that way.
Pontuação 6
7 comentários:
The real problem is with the bluetooth/WiFi card. It wasn't working before the system update. I'm afraid of removing the parts of ps3 and soldering. The SONY service centre said that, my ps3 can't be repaired and can only be replaced with a huge amount. What should I do now? Can I skip the update loop without completing it?
por
If the Bluetooth is bad, then no. The DualShock 3 uses Bluetooth to connect to the Ps3.
por
Yes, that's right. My controller is not working wirelessly. But please tell me a solution to skip this update. I cant play now. When I turn on the system, it will directly starts updating and repeats the same problem. I have no access to the XMB menu now... Please tell me a solution to skip this update without updating it.
por
Try this. While the PS3 is off, take out the hard drive. When you turn the hard drive back on, you will get "missing hard drive error code". Without turning off the PS3 again, simply insert the hard drive. According to another thread, the update may continue. Otherwise you will have to replace the bluetooth chip.
por
When I turned on my PS3 without hard drive, it shows a message like " hard drive is missing". No updates are going on that time. As you said, I inserted the hard drive without turning off the PS3, but nothing had happened. After sometime, I restarted my ps3 without removing the hard drive. Soon, the update started and stopped at 61%
por
Exibir mais 2 comentários
Had this error also. I let it restart on its own a few times but still get the error. So I held the power button down till beep (PS3 shuts off), unplug the power cord from socket for a few minutes (2-3 min should be good), plug it back in to socket, press the power button, update install should start up again. Mine completed after that!
Pontuação 3
2 comentários:
Was your ps3 connected to WiFi before you started the update?
por
Ayuddaaaaaa mi ps3 no quiere actalizar
por
Error code 8002F1F9 means your bluetooth/wifi module isn’t working properly. That could mean the module, components on the module, or components connected to the bt/wifi module are faulty. Sometimes it can be fixed with a voltage regulator. I know this is an old thread but these are just suggestions/starting places for anyone that is still dealing with this. There’s no guarantee that any of this information will help you.
Source for error code:
Voltage regulator potential fix:
https://www.psx-place.com/threads/super-...
Pontuação 2
2 comentários:
I want to update my ps3 system but I saw this
Further notice.please remain on this firmware
And I have waited for an hour now I have seen nothing
What should I do please
por
Still relevant and helped me figuring out it was all caused by a loose ribbon cable (from motherboard to wireless module).
por
Nesesito ayuda mi ps3 no quiere actualizar me dise de a producido un error 8002F1F9
Pontuação 0
I also have this problem. I tried to update my brother’s PS3 then it got stuck at 41% and showed the same error. I don’t know how to take apart and I can’t learn how to. Have a solution? Please I need to fix it.
Pontuação 0
1 comentário:
You can't learn how to?
por
Adicionar a sua resposta
Shinju Shaji será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 36
Últimos 7 dias: 221
Últimos 30 dias: 1,124
Duração total: 100,005
