Ir para o conteúdo principal
O PlayStation 3 (mais conhecido como PS3) é o terceiro sistema de entretenimento doméstico produzido pela Sony Computer Entertainment e o sucessor do PlayStation 2. Foi lançado em 11 de novembro de 2006.
I am getting error code (8002F147) on my PS3
Alright so I have 2 PS3s. My friend let me borrow his broken ps3 to try to fix it. The problem is that he unplugged the AC unit during the update. So now I have error code (8002F147). Everytime I tried to restart it, it still went to update. It goes to about 36% then it gives me the error. It's an endless loop of errors.
IS THERE ANY WAY TO FIX THIS BESIDES SENDING IT TO SONY???
Esta é uma boa pergunta?
Pontuação 26
3 comentários
My nephew just brought me his PS3 today with the same exact problem. I will try messing around with it and I will let you know what happens.
por
Plz let me no the problem too
por
السلام عليكم اردنا ان نقم بتحديث البلاستيشن ٣ و عندما انتهى التحديث ضهرت رسالة تقول بأنه تم حذف التحديث السابق و يتم التحديث الان من جديد وبعد ان ينتهي من التحديث يكتب فشل و اذا اردت اتصل على 8002f147
كيف اعمل انها عملية متكررة عندما تشتغل يبدأ التحديث مباشرتا ونحن في الوسط اي انه لم يتم التحديث ولم نستطع الخروج من التحديث
por
Adicionar um comentário
11 respostas
Solução escolhida
I found this answer on a forum (link below):
  • take out the hard drive
  • connect hard drive to pc
  • open up disk management - in win7 it asked me to make a master book record, so I did.
  • format in NTFS - that's right, NTFS - don't use quick format
  • get the rom of whatever version you were on before you upgraded - i had to search, but i found the us 3.30 rom
  • copy that rom to usb drive in folders PS3 ==> UPDATE ==> put rom named PS3UPDAT.PUP here
  • shut down pc, take out hd, take usb drive too
  • put hd back in ps3, put usb stick in ps3
  • boot ps3
  • a screen will pop up. press select + start
  • another screen (i think) later, press select + start
  • configure your ps3 setup - done
(source: http://forums.demigodthegame.com/386771)
Esta resposta foi útil?
Pontuação 9
5 comentários:
Yes I seen that. I dont have a SATA cable though so I just tried to update via full format on other PS3. It might work.
por
Every time I try to update my ps3 to 3.55 firmware it give these error code80028cca
por
Super slim ?
por
There is no hard drive on my ps3, what to do
por
The problem persists in the drive strip make sure its plugged in good and tite on both ends from drive to board i had to add a small thick piece of paper to the stripp to make sure it was snug and make sure the little black lever is up b4 u insert and pressed down when snug i just did this and it installed first try
por
Hey man as I mentioned before my nephews PS3 had the same problem. All I did to fix it was:
  • tear the entire PS3 apart to clean it and re apply thermal paste.
  • While I had the mobo out I thought about removing the PRAM battery to see if that would fix the update error.
  • After I put the PS3 back together I turned it on WITHOUT a hard drive then when the missing HD error came up I inserted the HD then turned the PS3 off.
  • I turned it back on and the update ran right off the batt as usual except it was updating much faster. I just let it finish and it actually finished the update and booted into the home screen.
All his saved data as well as media was still there and it is now running fine. I do not think you have to do the whole thermal paste deal but just remove the PRAM battery for a while then try what I did with the HD. I hope this helps. Good luck!!
Pontuação 3
3 comentários:
I can confirm that this solution will fix the problem. Granted, the PS3 I was working on was giving the 802F1F9 error, but it is worth a shot. I did not do any thermal paste re-application, just removed the small onboard battery for a minute or two, reassembled, and start it first without then with the harddrive. Nice fix. +
por
can not be formatted if the windows 10
por
nope still getting the error...
por
Does anyone know where I can get the 3.30 or 3.40 firmware? I'm currently stuck with the same issue. {PS# SLIM 160GB}.
Thanks in advance!
Pontuação 2
I need repair this error plz
Pontuação 1
error code 8002f147 refers to a problem with your disc drive/blue-ray player, if you have recently had it repaired from ylod or other problems that's probably whats done it, there are little plastic clips connecting the lead from the main board to your drive and i bet you find its broke or if its not been fixed lately i think you may need a new drive!!!
Pontuação 0
1 comentário:
You can't replace the blu-ray drive on a PS3 the motherboard to the drive is married to the motherboard of the console. They are a set that can't be separated and work. Please do a Google on the PS3 error code 8002f147, it is a firmware error.
por
the windows 10
Pontuação 0
Nothing has helped. Same error. PS3 slim. I used three new drives. All kinds of formatting. Downloaded newest firmware. It recognizes the drive with firmware and even displayed it on the screen. Still no go. Any ideas?
Thanks.
Pontuação 0
Okay hi my ps3 is stuck on updating and it won't come off or reset just keeps coming up with error 8002f334 or nothing what to do please help
Pontuação 0
hi,i have problem code error 8002f147 on my ps3 if i update system..
please help me
thanks
Pontuação 0
1 comentário:
Hi anyone knows about error 8002F271? This does not appear in any of my searches be it goodle or youtube. I need to know first what this error means?
por
Posted: 10/31/2017
Options
Pontuação 0
Hi having error code 8002F147 on my PS3
Pontuação 0
Adicionar a sua resposta
impactsk8er100 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 34
Últimos 30 dias: 97
Ao todo: 90,639
