Ir para o conteúdo principal
Model A1288 / 8, 16, or 32 GB capacity
451 Perguntas Visualizar todos
does any one have hardware diagnostic software for iPod?
Does anyone know if there is any software that you can download on your computer then plug in your ipod and run a hardware test to see why my ipod wont work?
if any one has anything similar please tell me...thanks.
i dont know much about it cause its someone elses im fixing for them but i do know that:
>at first it was just the digitizer that stoped working,(was'nt broken) then i replaced it, and that did'nt help eather so i tried a couple other ones and no luck w/that. i dont know if it has been water damaged or droped but everything worked (except digitizer) until i took the logic board out and put it back in then it did'nt turn on...any ideas?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
The only piece of software that I know of is CopyTrans Doctor It has helped me once with a HDD error and is somewhat limited in what it can do. I do not know of any software for ipod that allows for diagnosis of any error. Sure would be great if there is. I think that the iPod diagnostic is the main software that checks on the hardware. Of course in your case it's tougher since your iPod does not react aat all. Let us know what your iPod is doing, Anything at all? could it be a power issue? Any water damage? Heat issues? Battery issues? did it get dropped? Any information will help to diagnose your iPods problem...Good luck
Esta resposta foi útil?
Pontuação 0
1 comentário:
I HAVE A 6 GENERATION iPOD TOUCH THAT STOPPED WORKING. I CHANGED THE BATTERY AND THAT WASN'T THE ISSUE. I ALSO CHANGED THE DIGITIZED STILL NO LUCK. NOW I JUST PUZZLED AS TO WHAT MY NEXT STEP SHOULD BE. ANY HELP WOULD BE APPRECIATED. THANKS IN ADVANCE!
por
Adicionar a sua resposta
Brock será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 15
Duração total: 4,036
