Toughbook CF29 Screen Replacement
Is it possible to replace the hole display of a Toughbook CF29 without opening an breaking the seal?
Thx
Esta é uma boa pergunta?
Thx
I do not think that this is possible. The only way would be to replace the whole top part, however, your cables will have to be disconnected on the inside of the panel. So I guess you will have to split the halves and reseal them after. Personal I think you will do fine with some silicon after as suggested. Good luck
Esta resposta foi útil?
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 10
Duração total: 1,196
1 comentário
I have the replacement part numbers if you need them to your toughbook.
just post the full model number (example: CF-29C3KGZ1M)
por S0U1SB4N3
