Ir para o conteúdo principal
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
79 Perguntas Visualizar todos
Camry Ignition Switch Removal
So I have a 1994 Toyota Camry 4 Cylinder. It is currently having some issues and im trying to replace the ignition switch not the lock cylinder and i got the first part detached but the other part that connects higher i have no idea how to get to it as i dont want to mess anything up.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Solução escolhida
Hi Michael,
The link below should help you get that ignition switch swapped out.
How to change key ignition switch
Esta resposta foi útil?
Pontuação 3
How to change ignition switch on a 94Toyotacamry
Pontuação 2
Adicionar a sua resposta
Michael será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 24
Últimos 30 dias: 56
Duração total: 4,216
