Ir para o conteúdo principal
How to service a vintage Mixmaster
Purchased 2 vintage Sunbeam Mixmaster Model 10 and Model 12. Both run but a strong chemical/burning smell is emitted. Has anyone serviced one of these machines and if so what type of grease / oil did you use. thank you
Esta é uma boa pergunta?
Pontuação 2
2 comentários
What if a model 10 leaks oil, but runs and sounds fine otherwise?
por
We service vintage Mixmasters at nelsonezy.com. We use Benalene 930-2 grease, but you can use any amber wheel bearing grease.
por
Adicionar um comentário
3 respostas
Solução escolhida
You can get free maintenance manual pages here:
http://www.davesrepair.com/pdfmanuals/mm...
Esta resposta foi útil?
Pontuação 4
4 comentários:
thanks for the link
por
What if a Sunbeam Mixmaster leaks oil from the beaters but runs smooth and sounds great otherwise?
por
Eileen See @oldturkey03 Oldturkey03 post below
por
Thanks for having posted this. I ordered one of the Sunbeam Mixmaster manuals for the models MMA, 1-8B, etc. from this website and the manual is incredible.
por
Pergunta mais útil
@terryasks Mixmaster grease is no longer available, but a good grade of high temperature automotive wheel bearing grease will work. Use only the best oil you can find, 'turbine oil' or Slick50™ engine treatment will work well. Great information from here.
Pontuação 6
1 comentário:
thank you, very helpful
por
We service all vintage Mixmaster models at nelsonezy.com. We use Benalene 930-2 grease, but you can use any amber wheel bearing grease.
Pontuação 0
Adicionar a sua resposta
Terry será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 100
Duração total: 8,803
