ISO: How to replace a starter 2.4 i4
Replacing a starter on my buddy's 04 Raliart Lancer and just need a service manual or write up on that.
Much appreciated
Esta é uma boa pergunta?
Much appreciated
@lawnmower20 take out the two bolts that bolt the starter to the transmission. One long bolt faces the driver side and the other faces the passenger side. Unclip the black plug, and take the nut off the power wire. Then rock it back and forth to remove it.
Esta resposta foi útil?
@lawnmower20,Jack, Use the attached video's similar car, same 2.4l engine and starter. Good luck.
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 53
Duração total: 3,234
