Ir para o conteúdo principal
A HP Deskjet Ink Advantage 1515 é uma impressora/scanner jato de tinta desktop multifuncional da HP. Número do modelo B2L57A#AKY.
Why the printer won't print
I tried printing but the paper just came out blank. Why?
Esta é uma boa pergunta?
Pontuação 2
4 comentários
I just replace the ink but can't print because the printer doesn't seem to grab the paper, the paper just went in half way and nothing was print on it.
por
Hi @ adnan abdul ajis,
If you have the HP 1515 can you copy or scan a document OK using the printer's control panel?
If it works OK this way, can you try a test print from the computer that the printer is connected to? (usually found in the Printer properties area in the computer)
por
hey my printer hp 1515 just wont print . i press print from my laptop and nothing happens
por
hey my printer error, it can scan but its cant prin, and i can open the properties..
por
Adicionar um comentário
1 resposta
Pergunta mais útil
No ink maybe? Lol does the rail for the ink cartridges move? Or does it simply spit the paper out
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Leolando Nable será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Ao todo: 3,608
