Wifi no hardware installed
Hello i swap my macbook air 2009 main board had ram issue i reheat and used for a couple of month until it died again i swap it but when taking out the screw i wrinkle a i little bit the wifi ribbon i turn it on it says on the wifi no hardware installed i restart the mac with command + s and use the command to check for any change on the ssd but says ok it reboots the wifi work for a while the it freezes and restarts by itself until again no wifi and with no wifi it does not reboot by itself so is it the cable or something else?
Esta é uma boa pergunta?
1 comentário
Any advaixe on the problem?
por carlos
