Ir para o conteúdo principal
O Kindle Fire, Fire ou Amazon Fire é um tablet de mídia baseado em Android da Amazon com tela colorida multitoque. O reparo requer apenas chaves e ferramentas de abertura.
orange screen no response
when i turn on my Kindle fire the kindle logo appears for a few seconds then the whole screen turns orange and nothing works, this is the second kindle i have had with the same problem, seems to be software but usb connection not working either.
Esta é uma boa pergunta?
Pontuação 11
4 comentários
Any luck? I have the same problem.
por Compartilhar
My screen turned orange, but that’s not all. The real problem is that it shows a partially filled page to Register my Fire. Password missing, so I write it, but nothing happens. Is non responsive.
If I try “forgot password” it sends an e-mail with an OTP but when I enter it, again, nothing happens.
I tried to reset the Fire from the Amazon page, but it doesn't work… apparently it can’t connect to the Internet.
Can any one help?
por Compartilhar
Mine starts up goes blue and then goes Kindle fire again then goes to bootloop
por Compartilhar
My Amazon tablet has went orange on my screen. Everything is working and letting me do things but it is so annoying and I need help!
por Compartilhar
Adicionar um comentário
1 resposta
Pergunta mais útil
swipe down from top of screen
select settings
select display
select "Blue Shade"
look down at "Automatic Activation
to the right side of the screen there is an oval with a dot to the left
Swipe this dot to the right. It will restore your screen to the normal color
Esta resposta foi útil?
Pontuação 10
7 comentários:
Thanks so much. I'm glad I came across you before I had a chance to go crazy. It was nice and super easy.
por Compartilhar
I have to thank you too !!!!!
por Compartilhar
Same here - usually when I try peoples online suggestions for various things, the problem still exists. Yours was simple and worked.
por Compartilhar
Thank you!!!back to normal color
por Compartilhar
Thank you so much. I knew how to brighten the screen but, the screen stayed orange until I read your instructions. It saved us a trip to the computer store and money!!
por Compartilhar
Exibir mais 2 comentários
Adicionar a sua resposta
Diana Osborne será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 16
Ao todo: 22,600
