Ir para o conteúdo principal
Replacing motherboard will the iMe change or stay the same
New motherboard will I get a new iMe or will it be the same one
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
7 respostas
Solução escolhida
The main board is the phone, changing it is almost equivalent to changing the entire phone, of course it will change.
Esta resposta foi útil?
Pontuação 5
1 comentário:
is it good idea to change motherboard (if yes why? if no why?) or we should go to new phone? please explain in detailed
por
Pergunta mais útil
Yes. Every motherboard has its own unique IMEI number. So if you take out your current board and swap in a new one, the IMEI number will be different.
Pontuação 5
2 comentários:
chane my motherbord miy1
por
por
10000% incorrect. The IMEI number on every logic board is unique.
Pontuação 3
8 comentários:
I given my mobile at the service center & they replaced its motherboard but problems in the mobile remained same, also I didn't get any new emi no.
I think they didn't replace its motherboard, did they?
por
No pliz they didn't change anything
por
Yeah they probably didn't. Yeah I replied pretty late..
por
My phone samsung s8+ has an issue with the iris scanning.so they changed the mother board. But to my surprise it has still the same Imei number ...
por
Yeah because they can change the IMEI and S/N on the board, they probably replaced the IRIS scanner instead but who knows.
por
Exibir mais 3 comentários
M swaped my iphone 6 last year. When I receive new phone its emei number was changed.
Pontuação 0
If I replace my logic board would my imei stay the same ?
Pontuação 0
1 comentário:
Each & every New/Used Logic(Motherboard) comes with a Unique IMEI Number Embedded with it. So, Obviously you'll get a New IMEI Number of the Swaped Board. But, those can also be Changed
por
I given my mobile at the repair shop and he swaped its motherboard with someone else old phones motherboard,is this safe or not???
Pontuação 0
Which chip or area on motherboard has stored the IMEI number?
Pontuação 0
Adicionar a sua resposta
Mark Anderson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 39
Duração total: 28,172
