Ir para o conteúdo principal
Um repositório de informações sobre o tema Plásticos. Inclui técnicas de restauração como a remoção de amarelamento, reparos e modificações.
How can I repair gouges in an ABS plastic kayak?
Bought a demo kayak with a few deep gouges. What materials do I need to repair them and what procedure should I follow?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
Barb Wiginton , If not too deep, they can be sanded out starting with a medium wet sand paper working through to a very fine paper and finish by polishing. A headlight restoration kit can work well in removing scratches and can be inexpensive. See links below for more info. Good luck.
http://paddling.about.com/od/kayaks/fl/H...
https://www.trails.com/how_39590_repair-...
https://www.youtube.com/watch?v=f3IrAUYH...
Esta resposta foi útil?
Pontuação 5
Bill, will this work on thermoformed boats as well as the rotomolded type you worked on, I believe the thermoformed boats are an abs material. It is quite a bit thinner than rotomold best inflatable kayaks, but lighter and some what similar in strength, but would suffer a bit more in rock gardening.
Just wondering if the tarp material would stick, and be a good keel reinforcer.
any info would be helpful, Thx!
P.S. This repair looks easy and strong! Very cool!
Pontuação 0
Adicionar a sua resposta
Barb Wiginton será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 48
Ao todo: 2,647
