Ir para o conteúdo principal
Compact digital camera with built-in flash with 10.0 Megapixel, 10x Optical Zoom and Image Stabilizer System. Disassembling requires the use of certain equipment.
20 Perguntas Visualizar todos
Batteries drain quickly even if new
As soon as the batteries are replaced and my Canon powershot SX120is is switched on,
while trying to take pictures the low battery signal appears flashing on the screen and the camera switches off automatically. I have tried with new batteries of the best quality i could find but the problem remains.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
might want a new motherboard. i have same problem and have enquired with Canon and local camera shops.
labour, postage and parts could be around £100.
unfortunately it may not be worth it. I don't use mine that often! parts for this model are discontinued with Canon as from November 2017. you would want an estimate and diagnosis before any work would be carried out,to be sure! around £40.
check if the shop can fix it and carry the spares!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Jean Hubert Noel será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 9
Duração total: 1,555
