Location of flasher relay
2002 flasher relay location
Esta é uma boa pergunta?
hrtly01 ,You do not have a signal flasher per say, It is built into the ETACS ECU. Check all bulbs/sockets/plugs closely and fuses under hood #8 10A, #18 10A and Interior #2 7.5A, #5 7.5A, #15 15A if not blown then may be problem with multi function switch or ETACS ECU.
Click on the link below to see where the Good luck.
Esta resposta foi útil?
Nice job on 40k, L Pfaff!
Thanks, George A, have a great day!
Thanks george
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 29
Ao todo: 9,874
