Ir para o conteúdo principal
Guias de reparo e suporte para a EOS 70D, uma câmera DSLR lançada pela Canon em 2013. Esta câmera pode ser identificada pelo número de modelo DS126411.
replace the mode dial on canon 70d
how do I remove the mode dial on a Canon 70d ??
I have a replacement.
Esta é uma boa pergunta?
Pontuação 4
5 comentários
Hi, did you manage to find out how to replace it? Having problems with mine, and have just ordered a replacement.
por
No, unfortunately I haven't replaced it. I found a posting on the net from a guy who enquired at Canon and was told that a strip-down costing a couple of hundred Dollars was neccessary.
Mine's is stuck on manual, so I've just been working with that.
por
Have done some research and have gotten in contact with a guy that repairs cameras. He told me I would have to strip off the casing before I can replace the dial (I think it's held on by a screw from the inside). Will be attempting the tear down when my replacement dial arrives. Will tell you how it goes.
por
Alexander,
I was quoted 248.00 for what might be a simple task. Where can I buy the mode dial? Have you actually accomplished this repair yet? If so, I'd like to know if maybe it was not so easy or worth the cost I was quoted.
Joanna
por
Alma,
Did you find a way to get that mode dial repaired?
Joanna
por
Adicionar um comentário
2 respostas
Pergunta mais útil
this post is a year old, but for those who are still looking for an answer on how to replace the dial mode on the 70d, or any canon dslr for that matter, you might want to see this video https://youtu.be/rpE7Co3dfgo
Esta resposta foi útil?
Pontuação 1
1 comentário:
thank you!!!!
por
My camera is ded no power
Pontuação 0
Adicionar a sua resposta
Alma Kohl será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 11
Últimos 30 dias: 44
Ao todo: 4,667
