Ir para o conteúdo principal
I need to replace a Laptop Envy case etc
I need to replace the Laptop Envy 15'6 case.
I also need to add 4GB of memory to use it as a 16GB memory laptop.
I also need HP to re-install my original OS Windows 8.0.
The free install of Windows 10 did not work, and Microsoft told me they can not fix it.
And left me with no OS. Just a Laptop that reboots with the HP logo repeatly.
How long will the above repairs take, and how much will it cost?
Please by email to smytheh@excite.com
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I'd say everything would take you about 10 hours as far as installing windows id give windows 10 another shot id download the windows 10 boot drive installer you can get free here https://www.microsoft.com/en-us/software... and you'd have to go in the bios settings of your computer to install it its different for every computer so you'd probably have to go into your user manual. Installing the ram will take a matter of minutes just make sure you buy ram that's compatible with your computer. as far as changing the case goes you'd have to go at your own pace but that would probably take me about 4-5 hours.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Hi @ibmguy9 ,
To add to Brad's good answer if I may.
Here is a link to the service manual for your laptop.
It shows the necessary pre-requisites and the procedures for removing all the parts from the laptop.
Also, in it you will find the part numbers for any parts that you wish/need to replace. Just search online using the part number only in the search box, nothing else, to find suppliers of the parts.
http://h10032.www1.hp.com/ctg/Manual/c04...
por
Adicionar a sua resposta
Howard Smythe será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 144
