Ir para o conteúdo principal
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
427 Perguntas Visualizar todos
Wont turn on. Diagnostic led no light
iMac does not power ON
Hi,
I have a Power issue with my mid 2011 iMac.
I've already opened it up. I have experience with repairing electronics, etc. But now i'm stuck. On the logic board ( Main board) :
Diagnostic LEd no light, I measure 12v and 5v on the supply.
Esta pergunta é pertinente?
Pontuação 4
2 comentários
@djdanny what is the exact model of your iMac? Which one of the LED's is not coming on? what else have you checked? The more information you give the greater the chance of getting valid answers
por
Imac 2011 mid 21,5" i5 quad core
No status led light on motherboard.
I check power cord and psu 12v and 5v
por
Adicionar um comentário
2 respostas
Pergunta Mais Útil
@djdanny if you have no LED light up you are having problems with the PSU. You said you tested it for 12V and 5V but are not telling us where and how you tested this. At this point I would consider starting by replacing the power supply and/or double check your connections etc.
Esta resposta foi útil?
Pontuação 1
I have the same issue, I only have led 1 and when i press the power button - led 1 shuts off. There is a little fan spin for a millisecond.
Pontuação 0
Adicionar a sua resposta
Djdanny será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 489
