Ir para o conteúdo principal
O OnePlus 2, o segundo dispositivo da OnePlus no mercado de celulares Android, foi lançado em 11 de agosto de 2015.
Call speaker not working
my one plus 2 fell in water and I can't hear anyone on opposite end wen I call.. I can hear em on speaker but not on handset.. WiFi too isn't working.. wat is the problem?? I can listen to videos and games but can't hear during calls.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
The OnePlus 2 uses two different speakers. The ear speaker just puts audio to your ear, while the loudspeaker provides sound for videos.
You will first need to remove the motherboard.
Once you have pulled it out the ear speaker should be easily visible at the top on the frame of the phone. Simply remove with some tweezers and insert the replacement.
As for the WIFI issues, could be some corrosion. I would clean the motherboard with 99.9% Isopropyl alcohol to see if that solves the issue.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
vamsi bhavans será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Ao todo: 987
