Ir para o conteúdo principal
OnePlus 2 Motherboard Replacement
O que você precisa
  1. OnePlus 2 Motherboard Replacement, SIM Card: passo 1, imagem 1 %32 OnePlus 2 Motherboard Replacement, SIM Card: passo 1, imagem 2 %32 OnePlus 2 Motherboard Replacement, SIM Card: passo 1, imagem 3 %32
    • Make sure that your phone is turned off before proceeding
    • Use an opening pick, your thumbnail, or a spudger to gently pry off the external casing
    Pergunte ao FixBot
    Comentar
  2. OnePlus 2 Motherboard Replacement: passo 2, imagem 1 %32 OnePlus 2 Motherboard Replacement: passo 2, imagem 2 %32 OnePlus 2 Motherboard Replacement: passo 2, imagem 3 %32
    • Locate the SIM card tray on the back of the phone
    • Use your thumb to gently slide out the tray
    Pergunte ao FixBot
    Comentar
  3. OnePlus 2 Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the SIM card tray
    Pergunte ao FixBot
    Comentar
  4. OnePlus 2 Motherboard Replacement, Battery: passo 4, imagem 1 %32 OnePlus 2 Motherboard Replacement, Battery: passo 4, imagem 2 %32 OnePlus 2 Motherboard Replacement, Battery: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Find and carefully remove all 6 rubber screw covers with the tweezers.
    • Unscrew all 18 screws from the mid frame.
    Pergunte ao FixBot
    Comentar
  5. OnePlus 2 Motherboard Replacement: passo 5, imagem 1 %32 OnePlus 2 Motherboard Replacement: passo 5, imagem 2 %32 OnePlus 2 Motherboard Replacement: passo 5, imagem 3 %32
    • Carefully pry up the mid frame from the back of the phone with the plastic opening tools.
    • Slowly work your way around the phone releasing all the clips that hold the frame in place.
    Pergunte ao FixBot
    Comentar
  6. OnePlus 2 Motherboard Replacement: passo 6, imagem 1 %32 OnePlus 2 Motherboard Replacement: passo 6, imagem 2 %32 OnePlus 2 Motherboard Replacement: passo 6, imagem 3 %32
    • Using the spudger tool, pry the battery up from the adhesive.
    • Once the battery is loose from the adhesive holding it down, use the spudger tool to pry up the connection from the battery to the phone on the top right hand side.
    Pergunte ao FixBot
    Comentar
  7. OnePlus 2 Motherboard Replacement, Front and Rear Camera: passo 7, imagem 1 %32 OnePlus 2 Motherboard Replacement, Front and Rear Camera: passo 7, imagem 2 %32 OnePlus 2 Motherboard Replacement, Front and Rear Camera: passo 7, imagem 3 %32
    • Use the spudger tool to pry off the connections at the bottom-right of the front-facing camera.
    • Be sure to disconnect both connections before attempting to lift off the wiring.
    Pergunte ao FixBot
    Comentar
  8. OnePlus 2 Motherboard Replacement: passo 8, imagem 1 %32 OnePlus 2 Motherboard Replacement: passo 8, imagem 2 %32
    • Use the spudger tool to pry off the connection on the left of the front facing camera.
    Pergunte ao FixBot
    Comentar
  9. OnePlus 2 Motherboard Replacement: passo 9, imagem 1 %32 OnePlus 2 Motherboard Replacement: passo 9, imagem 2 %32
    • Use the tweezers to lift up the camera from its groove.
    • The camera has a long, flat portion at the bottom, so be sure to slide the camera up while lifting it up.
    Pergunte ao FixBot
    Comentar
  10. OnePlus 2 Motherboard Replacement: passo 10, imagem 1 %32 OnePlus 2 Motherboard Replacement: passo 10, imagem 2 %32 OnePlus 2 Motherboard Replacement: passo 10, imagem 3 %32
    • Use a spudger to pry off the connection below the front-facing camera.
    • Using the tweezers, carefully remove the camera from its groove.
    Pergunte ao FixBot
    Comentar
  11. OnePlus 2 Motherboard Replacement, Charging Port: passo 11, imagem 1 %32 OnePlus 2 Motherboard Replacement, Charging Port: passo 11, imagem 2 %32
    • Use the spudger tool to pry up the top connection of the charging port.
    • Follow the cable with the spudger and slowly pry it up from the adhesive holding it down.
    • Stop at the next connection.
    Pergunte ao FixBot
    Comentar
  12. OnePlus 2 Motherboard Replacement: passo 12, imagem 1 %32 OnePlus 2 Motherboard Replacement: passo 12, imagem 2 %32 OnePlus 2 Motherboard Replacement: passo 12, imagem 3 %32
    • Again, using the spudger tool, pry up the final 4 connections on the charging port
    • Again, just like before, slowly follow the cable with the spudger tool lifting it up from the adhesive backing.
    Pergunte ao FixBot
    Comentar
  13. OnePlus 2 Motherboard Replacement: passo 13, imagem 1 %32 OnePlus 2 Motherboard Replacement: passo 13, imagem 2 %32 OnePlus 2 Motherboard Replacement: passo 13, imagem 3 %32
    • Using the spudger tool on the bottom of the phone, push the charging part inward.
    • Once the charging port is free from the frame, use your fingers to remove the charging port the rest of the way.
    Pergunte ao FixBot
    Comentar
  14. OnePlus 2 Motherboard Replacement, Motherboard: passo 14, imagem 1 %32 OnePlus 2 Motherboard Replacement, Motherboard: passo 14, imagem 2 %32
    • Use the spudger tool to pry off the long wire connecting the motherboard (top) and the daughter-board (bottom).
    • Try to use the spudger to pry off as much of the wire as possible before attempting to remove it.
    Pergunte ao FixBot
    Comentar
  15. OnePlus 2 Motherboard Replacement: passo 15, imagem 1 %32 OnePlus 2 Motherboard Replacement: passo 15, imagem 2 %32 OnePlus 2 Motherboard Replacement: passo 15, imagem 3 %32
    • Use the spudger tool to pry off the 2 connections at the bottom-left of the motherboard.
    Pergunte ao FixBot
    Comentar
  16. OnePlus 2 Motherboard Replacement: passo 16, imagem 1 %32
    • Use the screwdriver to unscrew the screw fastened at the bottom right of the motherboard.
    Pergunte ao FixBot
    Comentar
  17. OnePlus 2 Motherboard Replacement: passo 17, imagem 1 %32 OnePlus 2 Motherboard Replacement: passo 17, imagem 2 %32
    • Use the spudger tool to pry up the connection at the top of the motherboard.
    Pergunte ao FixBot
    Comentar
  18. OnePlus 2 Motherboard Replacement: passo 18, imagem 1 %32 OnePlus 2 Motherboard Replacement: passo 18, imagem 2 %32 OnePlus 2 Motherboard Replacement: passo 18, imagem 3 %32
    • Insert the spudger tool underneath the bottom right corner of the motherboard.
    • Gently work your way around the underside of the board, making sure that it is completely detached before attempting to remove it.
    Pergunte ao FixBot
    Comentar
Conclusão
13 outras pessoas executaram este guia.
Kayla Williams
Membro desde: 10/01/15
1.544 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 4-5, Maness Fall 2015 Membro de Cal Poly, Team 4-5, Maness Fall 2015
CPSU-MANESS-F15S4G5
4 Membros
Autoria de 19 guias
3Comentários do guia
Perfect. How can change de microphone and audio plug?
something?
Adolfo Mendoza Gutierrez - Responder Compartilhar
where can i find the replace of the motherboard?
Georgina Patron - Responder Compartilhar
hi,
where the wifi antena location?
Nimrod Cohen - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 78
Ao todo: 13,333
